Mobile CPU compatibility - C7M and Pentium M
LoneWolf
I haven't found the answer to my question yet after some searching, so hopefully someone here will know.
I'm getting an extremely basic laptop for my folks, for internet/e-mail. I'm looking at an Everex someone had used for two months, and is selling since their parent rarely uses it. It has a 1.5GHz VIA C7-M cpu, and for what they need (and because it's cheap), I'm fine with that --for now.
I know that the processor is a socket 479 NanoBGA2. I also know that this is the same socket as the Pentium M and that Intel licensed their technology to VIA. But while I know a Pentium M would be pin compatible with the machine (should I choose to upgrade it), I'm not sure that the two are electrically compatible. If anyone has had some experience with this, I'd be really interested to know about it, since it's possible I'll eventually receive a dead machine with a working Banias or (preferably) Dothan-core CPU in it.
I would have initially said no, it won't support the Pentium-M but after searching it a bit, there is a chance it may. What you really need to do is find out what kind of chipset that laptop has and verify if that chipset supports the Pentium-M cpu.
The source that may suggest Pentium-M support for a VIA chipset:
http://www.windowsfordevices.com/news/NS7808334147.html
