mobile 754 athlon 64 help
so my brother came back and im on his athlon 64 3400+ with 512mb ram right now and i noticed that the computer loads extremely slow so i downloaded cpuz and im getting a reported clock speed of less than 800mhz there is no option in the bios to change voltage, clockspeed or anything. So the only way i can think of changing it is with clockgen which is also reporting <800mhz. What should i do? im a novice overclocker, but i have some idea of knowing what im doing.
thanks
-adam
I believe it's Cool'N'Quiet doing this. Disable this in the bios and you will get it running fine. Otherwise, update the BIOS.
Be advised that mobile 754 processor has a compatibility issue with most motherboards or not even supported.
Dude ,you need to do alot of reading first (cause it's booting slowly ) your going to try to O/C it !? I don't think so . Clean the hard drive of all the junk, do a adware scan &spybot scan in safe mode, then defrag it ,then go to run ,msconfig and see how many things are starting when you boot ,then spen the whole next week and read allbout the machine that your on ,and then when your done come here and read another week in the search mode on everything thats here on that machine ,then you talk about a possibly Over Clocking it.
Is it a laptop or desktop ,and is it a mobile chip (i think it is ) cause for some reason it has reverted back .and that is the norm when you install a 754 on a desktop board . The cure is to go into bios and configure the chip voltage and multi ( 1.50v and x11) but if your not familiar with it ,you have to read or be walked threw it.
