MNPC 600T Window.
Copyright
Finally got my window in... it was worth the wait!!! Just thought I would share. Sorry the pics are kinda crappy.
I am not sure if its the placement of the fans or the fact that wire grills don't block as much airflow.. my vid card temps dropped a solid 2C... and I already had the two fans blowing on the video card before the window.
Just wondering but what are your temps like?
Also how can i get a clear panel like that for a 600T or a 800D clear panel would be badass too..
Looks awsome!
My temps are great..Video card idles at 39C and loads at 65C playing BF3. CPU idles at 29C and loads at 80C with intel burn in. Now keep in mind I am only using a 1,200 rpm LED fan which isn't exactly the best option.
To get a window contact these guys...
http://www.mnpctech.com/
SWEET! Glad I wasn't the only one who put a bobble head in his 600T! Check out mine real quick, I did a vid with Cap in it: http://www.youtube.com/watch?v=gVMWF5rztig
Post your rig up on OCN. It's NICE!
Yeah! I saw your's recently. I thought I was the only one with a bobble head inside lol. Looks awesome man! I need to post my updated pics in teh 600T club section on OCN.
EDIT: Updated my pics on OCN :)
mnpctech did a really nice job there.
case looks clean and crisp.
nice job.:D
nice job.:D
Thanks, MNPC Tech does great work. I have a few of my buddies wanting to build something like mine so hoepfully I can bring them some more buisness.
The only thing you may want to consider for your window fans are these: http://www.frozencpu.com/products/2...Black_Aluminum_Fan_Filter.html?tl=g47c223s549
These mount easily and the fine screen on the outside really cuts down on dust inside the case. The screen can be easily removed and cleaned or simply vacuumed clean.
I use them on all my computers with fans pulling outside air.
Yeah I had thought about those but so far dust hasn't been to big of an issue. I blow the case out every 3 or 4 weeks. Right now it has a positive pressure setup which might be helping. I wonder if htey make those dust guards in white.. or if I can fit them on the inside of the case..
As far as I know they come in blue, clear and black.
You can mount them any way you like.
You could always paint them, too.:D
Thank you, Appreciate it! Just tell them after Jan 15th, thats when we return from CES...
Wow this gave me so many ideas for my 600T. Now I have to get a window that big or make one.
man...
I emailed MNPC tech a couple times (about 9 months ago) trying to get one of these windows.
never did hear back, so I finally just did my own thing.
your side panel looks good though.
I've said it before, but the 600T just looks killer when fitted with a HUGE window (imho anyhow)
man...
Now that window rocks, Good job :)
Good job man! I had no issues getting ahold of MNPC multiple times when I delt with them. Not sure why they didn't follow up with you.
Thats the style window Corsair should be offering! great job turbogeek!.....and Mnpctech only started offering their cnc milled acrylic 600T panel to the general public, 4 months ago. I will ask them to check our email records after Holiday break, just to make sure nobody else's inquiry is missed again, Sorry about that!!!
