Quick question for you guys;
At the moment I am running 2x1GB of Corsair XMS PC3200 ram. It's high performance and rated at 2.75v (which is what I run it at). Since upgrading to 64 bit o/s it is fast being used up, and I've found an old unused kingston 1GB PC3200 stick I forgot about. Problem is, that it's value ram.
http://www.ebuyer.com/product/55296 (same as this)
The timings are a lot lower and it's rated at only 2.6v. I wouldn't expect it to run at the same speeds as the XMS, so is it safe to slow the timings/voltage down to accommodate for it? i.e whole system [email protected], CL3 etc... I know it's a waste of the XMS performance but i'd rather the extra memory over speed. Since it's not designed for this, will it effect the stability/life span of the XMS ram?
Thanks,
Dawson
Thanks,
Dawson
