mixing memory need help
apcor
Was wondering if anyone could tell if this will work well before I try. I currently have 2 gigs of corsair pc8500, and I'm playing a stalker mod that chews up memory. I happen to have a spare stick of cruicial ballistix pc6400 and thinking putting it in to help ease the burden. Will this work out well or do you think it would cause more trouble?
Thanks
Are the all the same voltage. If so you can run the PC8500 ram at PC6400 speed and timings and all should be well.
