Mixing it up...
mrmagoo_83
Ok I have an Asrock board that has both an AGP and a PCIE slot, and it states in the manual you can use both at the same time.
I recently came into a ATI X1300 PCIE card, I am currently running a Nvidia 6600 AGP card.
Anyone know if the driver packages will go nuts from having one of each type installed? I am going to attempt to avoid installing the 'control panels' for both types and just install the drivers...maybe. Probably cannot avoid that.
Thoughts?
if your running XP you can install two graphic card drivers. if your in vista forget it
So much for that idea, I dont know how Asrock figures you can install both, because any decent AGP card with a decent HSF covers up the PCIE slot. Idiots...oh well.
