Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
depends on many factors, such as what OS your will be running, what board you are running it on and whether your OS is installed on one of these drives.
JBOD or a level 0 array will give you cumulative capacity. NvRaid allows spanning across controllers so if you have an nforce based mobo you should have the hardware to do it. Just be aware there are risks running an array, and do your homework before committing to it.
In linux, u can mix and match what u want, however you want...
in windows u need to make sure u setup dynamic drives and follow the normal window raid modes/jbod mode rules...
i would not jbod the drives, but u could prob getaway with mirroring thsoe drives. I wouldnt stripe drives like that either... general raid principles & safety considerations apply. So I would have to ask why you want to do and what OS u want to do it in...
