Mixing 270X and 280X
Core32
So the dilemma is this:
All the 270X cards I have run fantastic using -g1 for gpu-threads. Not so great with -g2.
I'm adding a 280X card but it runs 150KH/s faster using -g2 for gpu-threads.
Apparently you can not set the -g option in cgminer differently for individual cards like you can say "gpu-engine" : "1100,1120,1140"
I tried and I get an error, even though cgminer starts.
I believe I have read there is a way you can specify which cards to use when you start an instance of cgminer but I can't locate where I read that.
Any one have a link?
I want to try running one instance for the 270X cards with -g1 and a second instance for the 280X card with -g2.
try sgminer I think that was one of the things added to it. There have been some branches away from the main cgminer that added that specifically.
I've had a nightmare mixing cards though. I didn't realize the 270x's ran better with g1, I'll give them a try but I was getting around 450k on all of my 270x's and haven't bothered tuning more.
I badly need my risers to get here so I can try to spread things out properly. Heat is killing me right now with the recent expansion!
270X with -g2
What other settings are you using with that to get the 450?
With -g2 so far my settings only get about 390K on the 270X.
With -g1 I can run steady at 480K.
I'd like to get close to that along with the 280X pulling above 750K which it can with -g2.....
Make another cgminer directory and run 2 instances of cgminer with appreciate DEVICE numbers.
The first instance run your -g2 cards only.
The second instance run your -g1 cards with the appropriate DEVICE command, BUT keep your -g2 card settings in the command line (core & memory speeds) so you don't change THEIR settings when running the second instance of cgminer.
A bit tricky, but I run a mixed rig like that with 2x 280x, a 5870 and a 5830 leftover cards at full speed.
I need to look up the "device numbers" tag.
Can it be used in a config file instead of command line?
The second instance run your -g1 cards with the appropriate DEVICE command, BUT keep your -g2 card settings in the command line so you don't change THEIR settings when running the second instance of cgminer.
Same question about config file vs. command line.
For command line, it's just -d X where X is the device(s) you want to run.
Run cgminer -n to list out your cards by device number.
Run a separate BAT file for each instance. (Or a Bat file to start each instance in sequence.)
Here is an example of a setup after you map out your cards with the -n command :
-n gives me :
Devive 0 : 280x
Device 1 : 280x
Device 2 : 5870
Device 3 : 5830
Instance 1 :
--device 0,1 --scrypt --thread-concurrency 8192 -I 13 -g 2 -w 256 --lookup-gap 2 --gpu-engine 1080,1080 --gpu-memclock 1500,1500
Instance 2:
--device 2,3 --scrypt --thread-concurrency 8000,6144 -I 13,13,18,18 -g 1 -w 256 --lookup-gap 2 --gpu-engine 1080,1080,850,850 --gpu-memclock 1500,1500,1000,1000
Gives me 750kh, 750kh, 405kh, 300kh = 2.2mh for that rig.
Hope it helps, took me a while the first time to puzzle that one out properly.
Can a 7950 run well at -g2? Was thinking about mixing a 280x with my existing 7950 on one of my rigs.
There's a fork of cgminer at http://k-dev.net/cgminer that can accept multiple values for -g . You can use it to run one instance of cgminer with optimal settings for the 270x and 280x. There is also a link there to the Lantis optimized .cl files that can improve hash by ~5%. The .cl miners can be used with the current cgminer, just delete your *.bin before using.
H.
I got a 280x and 270x working in my rig using the Kalroth cgminer and doing the following,
First running a very vanilla batch file:
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
timeout /t 4
cgminer.exe --scrypt -o stratum+tcp://themagepool.com:3333 -u -p
Once cgminer got started I had it spit out a conf file and then I put in all my desired values as such: (while cgminer is running,, press S, then W to get a Conf file). * note you must have your card order figured out to adjust accordingly*
"pools" : [
"url" : "stratum+tcp://themagepool.com:3333",
"user" : "",
"pass" : ""
"intensity" : "13,20",
"vectors" : "1,1",
"worksize" : "256,256",
"lookup-gap" : "2,2",
"gpu-threads" : "2,1",
"thread-concurrency" : "8193,22000",
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "1",
"failover-switch-delay" : "60",
"gpu-dyninterval" : "7",
"gpu-platform" : "0",
"log" : "5",
"log-dateformat" : "0",
"no-pool-disable" : true,
"queue" : "1",
"scan-time" : "1",
"scrypt" : true,
"temp-hysteresis" : "3",
"shares" : "0",
"kernel-path" : "/usr/local/bin"
and I ended up with this:
Now I have to figure out how to adjust my rejects on my second card.... :)
Running Linux here. No Windoze if I can help it.
I hope to have time to try Yakk's method listed above since I won't need to recompile cgminer to run it.
By the way, your numbers WLL77 are what I am getting now with both at "-g1".
I expect to get the 280X over 750 once I get it running "-g2". (Fingers crossed).
You could try sgminer then as _r2h said. It was made for linux. The config file and such is really not different at all. Main thing is that you don't have to use the "--script" argument.
google sgminer,, should find a reddit and litecointalk links which both have tons of info on running in linux.
Edit: read a little deeper,, i see, you don't want to have to mess with recompiling, have only dabbled with linux,, so I know that can be a bit of a hassle.
My 280x,, is a sapphire dualX and it was a pain to get to higher hash rates,,, originally was at like 670kh,,, one major tip I came across was using a thread concurrency of 8193,, for some reason the odd number really works. that screen is a little off too, due to cgminer slowing down when I open anything,, the 280x runs at 735khz.
Thanks. Not quite a noob to linux compiling but getting all the files local that are needed to compile was a hassle when I first did it for this version of 3.7.2 that I am running.
I was able to get Yakk's double cgminer load running with better results.
Still getting 480KH/s with the two 270X cards and now I am getting 715KH/s with the 280X.
Lowering the core clock to 1020 instead of 1100 was the best boost I saw.
Can't see your clock settings in that picture.
Clock is set at 1050. Have been messing with undervolting as well,, have it down to 1084 in afterburner.
Easy solution: wrong multiple instances of cgminer. Run the 280X in one instance. Run the other cards in the other instance.
I use guiminer and just run multiple instances, works fine and I'm getting a pretty good hash rate. 280x, 7750, and 6400k apu.
sgminer support multiple -g values.
Alright. Running multiple instances of cgminer 3.7.2 "sort of" worked.
But looking at the results I could see the second instance start and it would actually change some values in the first instance setup :(
So I but the bullet and compiled the latest two versions of sgminer.
Damn it if I don't get this error when I start with two values for gpu-threads:
[18:55:09] ./sgminer: --gpu-threads: '1,1,2' is not a number
And no, I am not using single quotes in the config file....
Any ideas?
That is why in my example above I put all the values in the second instance.
Didn't seem to matter, and I tried starting both first and last but either would affect the other, eventually.
