Mixed WD10EADS & WD10EARS Raid?
-Sn1PeR-
I currently have 4x WD10EADS drives in a software raid 5 on my ubuntu server. Newegg is holding their sale today of WD10EARS drives -- will it work for me to add a few more and grow my array?
Also, will a WD10EADS and a WD10EARS drive work together for a Raid1 in Windows 7?
Yea they are fully compatible.
Please check for alignment though; your partition on the RAID should start at sector 2048 not at 63. You can check this with GParted, right click your partition and click Information.
Can you link any good articles on Raid alignment? I'm still having trouble grasping the concept and idea behind alignment. When I boot up gparted it does not show my /dev/md0 partition, but it does show each drive individually. When I run 'sudo gparted /dev/md0' it shows /dev/md0p1 as an Unknown ext3 filesystem.
I'm seeing Sectors/Track: 63 in gparted, making me think I'm not doing it right. Any ideas?
First sector: 0
So it's perfectly aligned. :)
Edit: oh i forgot, could you also show me the partition on the individual disks (/dev/sda /dev/sdb /dev/sdc /dev/sdd) - each has a partition on it; you would need to look that the partition on the raw disks is aligned, too. It should not start at sector 63.
The Cylinders Head Sector (CHS) addressing is a very old way to communicate with drives. Though you still see it appearing now and then it has no real relevance anymore. Today we think in LBA addressing; as in the disk starts at LBA 0 (sector 0) and ends at LBA <high number> being the last sector on the drive (or partition).
