Mix and match sli?
antok86
can i mix gtx1080 mfg and types or does sli have to be the same make and model/fg etc
Doesn't have to be the same manufacturer.
But don't make the same mistake as I did. I have two different manufactures and the height of both cards is different. That made my hardline build a lot harder and I had to just stick a soft tube between the two. If you don't intend on doing hardline setup, then it doesn't matter much.
But before you buy, check the warranty, BIOS settings (I heard that Asus is limiting voltage on their new Strix cards), etc. Stuff that might be important to you.
Yea not gonna hardline...just more for testing purposes. I know i might have to use a flex cable on bridge connector if that doesnt align rather than the HB sli connector
if you double up the ribbon type its the same as a HB bridge. just in case you didnt know...
