mITX or mATX for a gaming box?
xchaotic
1. What will you be doing with this PC? Gaming, HTPC, backup server
2. What's your budget? As long as the costs are justified I am fine with it.
3. Where do you live? UK/EU
4. What exact parts do you need for that budget?
I am already fairly set on 3rd gen i5 + 2x8GB RAM + GTX670, the rest is up in the air.
5. Not reusing any parts.
6. I'd love to see Thunderbolt passthrough to dock my Macbook Air, but can't see any mITX mobos with TB.
7. What resolution output do you need? 1 screen 1920x1200
8. Does this system need to fit into a particular space? No but it will probably sit under the desk as opposed to on it, so the small size might not be such a big advantage...
9. Only stock cases.
10. How important is the noise/silence of this sytem? Very important - whether in my office or the living room I wnat the system to be quiet at idle and media playback modes. a Little hum while gaming is acceptable.
11. How mobile does this system need to be? I am thinking of taking it home for Xmas and longer winter weekends.
12. Do you already have a legit and reusable/transferable OS key/license?
No can I already get win8 license with downgrade rights?
13. When do you plan on building/buying the PC? Immediately or in couple weeks if I should wait for Asus mITX mobo for example.
Other than that, I need a system that will run 24/7 so need a low idle power draw, the ca 20hrs/week of gaming and at least 40 hours of work coding/running VMs etc, probably 4-5 hrs a week serving as a media streamer.
Like I said it would be ideal if I could dock my MBA using Thunderbolt and plug just a single cable, but it probably won't work even with a bigger motherboard?
Finally, the noise is probably the most important consideration, and I'd much rather have a slightly larger box than issues w/ heat/noise. Having said that, a little noise under heavy load is acceptable.
I would say it depends on how many sata ports you need, both Asrock and ASUS itx boards which are the only ivy z77 itx boards out only have 4 ports, if you need more then you'll have to bump it up to matx, or get creative with the mSATA slots.
Figure out how many ports you'll need and then we can continue.
If I'm reading too much into your needs for "Backup server" then just let me know :D
I will only need 3 ports, one for slim Blu-ray and the other ones for SSD and a massive HDD.
The reason I don't need RAID or anything like that is I backup to multiple locations instead, which gives overall better level of protection (even if that particular machine/disk is more likely to fail) and I only back up ca 50GB of user data anyway.
By now I am fairly set on the Silverstone case (but which one) with a 600W PSU and AsRock mo'bo as it's cheaper.
Given how little choice there is, it turns out it's quite easy to put the parts together.
My 2 main areas of concern:
1. low-profile RAM - what brand to get so that I don't have to remove the useless fancy heatsinks?
2. It seems H80 is the biggest cooler that will fit in Silverstone ITX cases. Could I fit H100 in some other mITX case? I don't think I need to, but would be nice to have the neadroom...
Off the top of my head sounds like the SG07/08 would be the smallest you could go and use the H80 and meet the other qualifications. There is a thread here with a SG08 and a H80 set up. As far as the H100 I'll let other more informed members about it guide you.
Look at my signature system.
Personally I ended up settling with a Antec Kuhler 620. Main reasons are that the tubes are longer so it makes the system easier to work, the thinner radiator creates more space for air flow, and the temperature difference between the 620 and the H70 I was using before are minimal.
As far as the SG08 goes I love it. Plenty of video card space, and the hard drive space is good. I've got a 3.5" 1.5TB drive, 1TB 2.5" drive, and a 128GB SSD. That and the power supply is nice a beefy. If you are into modding it could be a nice case to play around with too (looking into dual all in one water coolers for the CPU AND the GPU :)).
Asrock motherboard is killer too...excellent overclocker and BIOS. Things like XFastUSB are nice too because it works.
Either way the decision is up to you...just look at my system as a nice reference system to what is possible.
Goodluck!
ADDED: Let me just say as well that you should also consider how important size is. What I mean is that if ITX will meet all your needs bar none then go for it. Having said that you also have to consider that mATX systems can also be built fairly small as well but they have extra stuff like more expansion slots, more RAM slots, more SATA, more hard drive space (depending on case of course), larger optical drive space (standard 5.25" vs. slim ODD), and your own power supply (that could be more wattage and more efficient etc).
Just food for thought! I personally love my ITX build with no qualms what so ever...I do wish I could use a better sound card but I'm making due with external USB sound, HDMI, and the integrated sound on the Asrock Z77E-ITX is pretty nice...full sound and no back ground noise.
1) Only available in 2x4GB, but Samsung RAM (link) is 200% awesome and doesn't stick out above the clips on the RAM slots. This is the best 2x4GB DDR3 kit money can buy.
Kingston has a 2x8GB kit that is low profile, but unknown whether it will do better than specs.
2) Bitfenix Prodigy is a mini ITX tower that can fit a 2x120 radiator on the top.
Alternate decent memory. No issues in my Z77E-ITX
Sorry to go off topic but loving the f'n name, that just made my day lmao....
I will say I have that exact ram, it's not too high for most low profile air coolers and definitely fits in small spaces where PSU limits height allowances.
The ram is also very fast and tested well in my new system, plus bonus.. it's cheap! I picked mine up at my local MN Microcenter for $45 I believe.
