mITX 16x to dual 8x riser card
Apollo686
I'm looking at setting up a mITX board in the Lian-Li PC-Q08 as a file server/nas but I need dual NIC cards and a hardware RAID card. It doesn't appear as though there are any socket 775 or 1156 boards that have dual NIC cards (wireless is not an option) so I will need to add both cards in.
The PC-Q08 has two slots for dual slot video cards, but obviously no boards have two pci-e. I am hoping that I can find a riser card that would allow me to go from one x16 pci-e slot to two x8 or x4 half height slots. If this is possible I could just use half height cards in the full size slots and have room for the riser.
The only think is I haven't been able to find anything like this. It seems like the bandwidth should be fine, but I'm not sure if there is a problem with splitting the PCI-e control channels.
Does anyone know if something like this exists or if there is another solution?
How about a Supermicro X7SPA-HF? 2x Intel NICs built in. Even if you get dual Realtek NICs you'll end up replacing them with Intel NICs at some point. The PCIe slot is only a x4 bandwidth wise though... but that is probably going to be good enough for anything you are going to build with a mITX board. Oh and you get things like KVM over IP and the ability to remotely mount DVD's from ISOs at the board level. It is ATOM based, but for a file server, that isn't too much of an issue unless you want to do media encoding on it.
I was trying to avoid Atom as I wanted to run a VMM on this machine, but I may end up just turning it into a NAS. Thanks for the suggestion.
Although not for Intel cpu's, over in this thread you will see J&W supposedly has a AM3 mITX board coming out with integrated dual gigE and pci-e x16.
If you really want to use VM's, consider moving to mATX. Slots are not an issue, and you can get quality Supermicro, Intel, Tyan server boards in mATX. There is a *huge* difference between something like a Supermicro X8SIL-F and a consumer board. Plus, the LGA1156 Xeon X3430 and X3440 are the about same price as an i5 750.
The one suggestion I have is to not settle for onboard Realtek, especially if you are running ESXi and also want to stream video.
