MIT Made Muscles Made Of Nylon
Discussion in 'HardForum Tech News' started by HardOCP News, Nov 23, 2016.
  1. HardOCP News
    HardOCP News [H] News
    0
    Dec 31, 1969
    Those big brains over at MIT have developed artificial muscles made of nylon. The simple, low-cost artificial muscles can make the same bending motions that real muscles make by applying heat to nylon fibers.
  2. illram
    illram [H]ard|Gawd
    1,449
    Sep 19, 2011
    So if you have nylon muscles are you by definition a *hans&franzvoice*girly man?
  3. The problem with hydraulic actuators are they are heavy and can be slow. It's one of the things that make walking robots so difficult. I wonder if they could be a future replacement? *rubs chin*
    <insert standard "Robots will kill us all" by Steve here>
  4. Jim Kim
    Jim Kim 2[H]4U
    3,468
    May 24, 2012
    WestWorld has been doing that for 8 episodes.
    Ducman69 and VooDooPC like this.
  5. spugm1r3
    spugm1r3 [H]ard|Gawd
    1,153
    Sep 28, 2012
    Step 2: Create robots that will kill us all.
  6. Yiffy
    Yiffy [H]ard|Gawd
    1,101
    Nov 5, 2001
    Maybe Ghost in the Shell's vision of the 2030's isn't as far fetched.... :O
    Ducman69 and whateverer like this.
  7. VooDooPC
    VooDooPC n00b
    21
    Mar 1, 2016
    Don't most robots use electric motors?
  8. KazeoHin
    KazeoHin [H]ardness Supreme
    7,843
    Sep 7, 2011
    So, if these fibres then use silver (or copper) wires in a snug coil around them completing a circuit at the other end, an input voltage would cause the wires to heat up in a very controlled fashion, allowing the ability to heat the whole length of the fibre evenly....
  9. potency
    potency Gawd
    848
    Dec 1, 2010
    They do but the type of movement and action they use cannot be found in nature.
  10. TechLarry
    TechLarry Can't find the G Spot
    30,141
    Aug 9, 2005
    In other news, the Sex Toy Industry just invested billions in artificial muscles made of nylon.
  11. Some do, and some don't. It depends on the movement you are interested in. For example some use motor cable tensioners and/or solenoids. (Like to move fingers in a hand) Edit: I forget pulleys and gearing boxes
    However to provide the torque necessary at the joint directly the motor would have to be very strong. And they tend to be sizable. Building actuators make more sense in these cases because they can provide both mechanical advantage, size, and flexibility in terms of DOF.
    If you look at the video here and see where they kick the dog sideways, it appears to have 4 DOF which is hard to do with sufficient torque in that small a space. You could use cable tensioners but reading the feedback on that system and calibrating the motor on the tension cable is a difficult problem. Hydraulics also provide sound minor feedback "bounce" for impacts, like a real biological system would.
  12. termite
    termite [H]ardness Supreme
    4,802
    Aug 27, 2004
    One step closer to our Robot Overlords taking human form.
  13. Hagrid
    Hagrid [H]ardForum Junkie
    8,398
    Nov 23, 2006
    Long as they are hot looking female killer robots.
    Live subject testing would be next! (not for organics?)
    More realistic robots would be cool in my book.
  14. Ducman69
    Ducman69 [H]ardForum Junkie
    10,445
    Jul 12, 2007
    Problem I see, is that they only show a nylon fiber bending, not really contracting much. Its the contracting that gives muscles their power.
    The weird thing in WestWorld though is that the 3D printer never appears to change its material, as the bone and muscle tissue seem to be of the same goo.
