I have a really weird issue:
My card is a Sapphire HD5670 Ultimate (link).
I have 3 monitors, Dell 2408WFP and 2x Dell U2311H. All were connected to HDMI (2408WFP), DVI (U2311H #1), DisplayPort (U2311H #2). None are using any converter cables, they are all homogeneous cables. They were working when I picked up the card last August and working until now.
I'm running Windows 7 Professional 64-bit.
The HDMI and DVI outputs are missing. I don't see them in AMD's Catalyst Control Panel. I don't see them in Windows 7's screen resolution menu.
The motherboard I'm testing it on is a ASUS P5N32-E SLI Plus. I only have one video card.
I tried this on another motherboard (ZOTAC NM10-BE), same issue.
The cables are not dead, the DVI cable works with another video card on another computer. This also means that the monitor is working as well.
Same with HDMI, I connected a PS3 to the 2408WFP with the same cable and it works.
What could possibly be the problem? RMA is an option but it's $60 or so and I'd rather put that money toward a 6000 series card with DP 1.2 (so I can use a MST hub and not worry about having a card with 3 digital outputs).
Any help would be great. Thanks.
