Alright, this is on a new build, just been installing drivers today. Windows XP pro, Sata DVD/cd burner, Asus motherboard. Hasn't been connected to the internet yet so I'm not worried about viruses.
I was reinstalling some drivers off of a CD for a sound card (Note Reinstalling, already installed them once and everything was working fine, just not all the speakers were coming on so I figured I'd try installing the drivers again and see what happened) and in the middle of the install I got a blue screen and a physical memory dump.
On reboot everything loaded up just fine, only Windows no longer recognizes the existence of the DVD drive. It still shows up in the bios fine, and I can boot the windows install disk off of it, but when I load windows off of the hard drive it doesn't register that it's there.
I'm sure this is a really simple fix, but if anyone has any suggestions as to the fastest way to get that worked out, I'm open to suggestions. Would I just need to find a CD driver to load onto the computer or is there something else I'm overlooking?
