I have some Intel X540 dual 10GbE network cards which I put into the below setups.
But for some reason setup 1, boots fine with no errors but only registers 24GB ram even though there is 32GB installed, remove the X540 and shows 32GB ram.
I have tried different PCIe slots too...
Setup 2 will not post with the X540 installed unless I remove one of the memory modules. When it dosen't post it shows error code 55 on the Asus diagnostic LED display
Setup 1:
Asus P8B-WS
Xeon E3 1245
4x Corsair Vengeance 1600Mhz DDR3 8GB
Setup 2:
Another setup
Asus P8B-WS
Xeon E3 1245
4x Corsair Vengeance 1600Mhz DDR 4GB
Anyone got any idea what would cause this? And how it can be solved?
I have run memtest, all ok. Installed the cards in other machines without an issue
Setup 1:
Asus P8B-WS
Xeon E3 1245
Setup 2:
Another setup
Asus P8B-WS
Xeon E3 1245
