After the recent Avast problem I decided to go to the MS security essentials program recommended here.
Installed it on my i-7 Vista64 box and it seems fine. Installed it on the wifes XP Pro 32 bit and all was okay until a restart and there is no icon in the notification area of the toolbar.
There is a desktop icon and when I click it, it says it's working and pc is protected.
I uninstalled and reinstalled it 3 times now. No tray icon to indicate working, problems or whatever. It's in the startup config set to go on when starting the pc and I've tried changing a bunch of options but no icon.
The wife brought it to my attention that there was no icon after I told her that there would be a green icon and not to worry that Avast blue icons would be gone.
It's disconcerting not to have it. Any ideas?
Thanks, Harold
Thanks, Harold
