Missing Heatpipe Bracket
I just bought a Shuttle SN85G4 v3 open box for a nice discount (about half price). I brought it home and noticed that it's missing the bracket that holds the heatsink down, (example, lower left.)
Anyways, does anyone know if I can get a replacement from Shuttle, or of any other places I can get a replacement bracket from? I looked over Shuttles' website and google'd it, but couldn't find anything. Of course, I'm probably just stupidly missing something obvious. :D
Thanks!
I have what you need
I have a 85 with a bad mobo anyways send me pm if you still need
Mmkay, I sent you a PM, Also, in the meantime, if anyone DOES know any obscure places for parts, I'd like to know, just so I know for future reference. :D
Acutaly that plastic socket on mobo ain't diferent from any other PIV sockets (S478) even on all G series AMD systems.
Hence some of Waterblock clams (for some smaller models of waterblocks for PIV) that are directly attached to PIV socket can be used.
Also some clams from some cheepo old PIV s478 HSF could work or be modifyed to work with.
Good luck
MD
