Missing driver for PCI Bridge Device?
jpsteinmetz
My friend just got a new Alienware system with an Asus P5ND2-SLI mobo. I installed the latest nForce4 Intel and ForceWare drivers for his system but there is still a PCI Bridge Device that is not finding the correct driver and installing. I was hoping that any of you with this board may have experienced this before? He's running XP Media Center Edition. Thanks in advance.
Just put the Asus cd in that came with the mainboard and it will fix this. You do not have to install anything from the cd, just put in in the drive and let it autoplay to the menu. This is a common issue.
Is this the "ATK0110ACPI" thing?
I've just spent an hour trying to figure this out.
-Larry
-Larry
I believe so, just put the cd in and see.
That will work unless Windows has (as it often does) mixed itself up and can't figure out the INF information any more.
FYI... The driver is in the Ai Booster folder, in the ACPI folder. If Windows has it's INF's screwed up, you'll have to force-feed it to that driver manually.
-Larry
