Hi,
I just did a fresh format of my system. I re-installed Civilization 4, which I downloaded from direct do drive a while back, and I am getting a System Error Message:
I have done my homework on google before I posted here but I cannot find a fix. This thread says what most of them do:
http://forums.civfanatics.com/showthread.php?t=111848
The problem is that I am using a 64 bit OS (WIN7). When I download the DLL and put it in the system32 folder it tells me I can't because of 32bit or something.
I have tried the following with no success:
- downloading dll file to system folder
- downloading dll file to game folder
- deleting all C++ installs (this actually caused problems and I won't do this again)
Any help would be great. I have run this game on Windows XP, Vista, and even on this Windows 7 System. This is the first time I tried to install it and got this message when I try to play
Civilization4.exe - System Error
The program can't start because MSVCR71.dll is missing from your computer. Try reinstalling the program to fix this problem.
