Missing Database Tables in Dreamweaver
mike400hp
Ok, I'm using Dreamweaver MX 2004 to create my company website. What I want to do is have a simple form page that our customers can enter information into and have that information go to an access database. I've done this before and never really had a problem, until now. For some reason I can connect to the database within Dreamweaver. The connection tests successfully. HOWEVER, when I click to expand the Tables, it shows that there are "None". When in fact I know that there are tables in the database I have connected to. Any ideas? Thanks!!
It seems like the best place for Dreamweaver support is the Macromedia website. You should check there for advice.
I had a similar problem and found a patch on their website. (I think the patch brought me to version 7.0.1, but that machine is at home and I can't double-check.)
