What is it that XP gets wrong?I would oppose simply adding the drive and formatting it in windowsXP does a bad job of this.
Is XP's setup limited to 127GB, or will it go higher if you specify a size rather than doing it "automatically?" I guess it shouldn't be that surprising since it's 6 years old (yes, there have been hotfixes and service packs for the OS, but I don't think the setup program has been updated has it? Does Service Pack 2 rectify this?).
It's a good idea in general to split the drive into 2 partitions. Keep the OS on it's own partition and all valuable data on the other. That way if disaster strikes and you're forced to format and reinstall, you can leave the other partition intact while performing a squeaky clean install.
Having everything dumped on C: is just retarded IMO.
