[RIP]Zeus
- Jul 16, 2003
Very effin nice..
I need to come over and look at this
A quick google search came up with these reccomended cutting tools for acrylic:
http://www.reefkeeping.com/issues/2002-04/jg/index.php
http://badmanstropicalfish.com/articles/acrylic/acrylic1.html
Both those websites provide some good information and Im sure if I poke around some more I can find some more information as well.
Im sure somebody here in the [H] forums has posted the ideal way to cut acrylic. I might end up checking the worklogs section as those guys are pros and do an OUTSTANDING job with their mods.
I will more than likely be using my circular saw to cut the acrylic, maybe a jigsaw. It all depends on what the local hardware stores have...
If they don't have the proper blade my Dad told be that Harbor Frieght sells circular saw blades pretty cheap and I might look into that as well.
As for the bad luck, I don't think I will unintentionally break the acrylic
This stuff is a lot stronger than glass![]()
