- Sep 26, 2008
Anyone know if this is possible? I'm using a program called selfimage to try to backup a hard disk. The disk is bootable (first partition is the boot menu, the second is the OS) and is larger than the drive I'd like to mirror it over to, but the partitions are small enough to fit.
disk 1 (250gb)
partition 1 = 200mb
partition 2 = 40gb
disk 2 (160gb)
partition 1 = 210mb (didn't format it when I created it, just raw space)
partition 2 = 41gb (same as above)
I tried creating 2 partitions on the "copy" disk approx the same size as the source (slightly larger than the source actually) and used selfimage to mirror the partitions over to their 'copy' counterparts. When I tried booting from it, it gave an MBR error. The rest of the space on both disks is unallocated and even tried making a 1:1 copy of the source disk, but the program said that it "probably wouldn't work as expected" due to the source being larger than the destination.
can you recommend some software that can do this?
disk 1 (250gb)
partition 1 = 200mb
partition 2 = 40gb
disk 2 (160gb)
