Mirror Array broken....
magik20
So i had a 2 drive mirror on a MSI board with a 3rd drive setup as a spare.
For some reason the array broke and is now showing 3 different drives all with the same data
how did that happen?
I've seen it happen before but the cause I couldnt figure out.
I would resetup the array asap then resync.
You should be fine without having to destroy the array so all data should be intact
