Mirc
jbweldon04
Hey guys. I just learned how to use Mirc pretty good finally!
Now I want to use it to chat.
Is there anywhere that displays a bunch of servers and channels that I can join to chat in?
Thanks in advance.
well your welcome to my channel on irchighway
just type in /server irc.irchighway.net
then once you connect do /join #donotwant
dont know if Hard has an irc channel if so id love to join
edit
if it seems like no ones around then just idle every one else does some one will pop in sooner or later im usely around in the evenings
/list shows all channels and how many people are currently in the channel. I think it shows channel topic, as well.
Edit: you use this command after you are connected to a particular server
