Minor problem with MSI K8N Neo 2
Mr Mean
Hello [H]ardmembers,
I am having this minor problem with my K8N Neo 2 motherboard. I have a raid setup for Serial ATA 1 and 2 and a backup drive for Serial ATA 3.
In Windows XP I have icon that appears with the title "Safely Remove Hardware", now this icon contains all my Serial ATA drives, including the Serial ATA Raid drives that are also seperated not as the single raid drive. Windows XP detects the drives as one but this Safely Remove Hardware program detects them as two. I need to get rid of this problem from starting up, is there anyway I can get rid of this program? Thanks in advance
Well...if it's any consolation, I just looked, I have two drives in a RAID 0 on an NForce 4 board, and the list of items I can "Safely remove" are two drives, instead of one in a RAID array.
Err...I don't think it's a problem though. Think of it this way, Windows itself sees them as one drive. You know they are functioning as a RAID array, if nothing else run a hard drive benchmark, or even the one for such in Sandra and see if the speeds are consistant for a RAID array. If they are, I honestly wouldn't worry about it. I think the "safely remove hardware" icon is just saying that yes, one can remove only one drive and not hurt the motherboard.
Now, if you're asking to get rid of the safely remove icon in general, I think you're stuck with it if you're using the NVidia RAID drivers. Only time I haven't seen it on NVidia SATA ports is if one isn't using any RAID array and thus doesn't install any NVidia drivers, and also refuses the NVIdia IDE driver when installing the chipset driver. Otherwise, I think you're stuck with it. Again though, I wouldn't worry about it, seems like everything is fine with that going on my end anyway, and never heard of anyone else having problems with it.
You can get rid of the "Safely Remove Hardware" icon...problem is, it appears as if it turns off write caching on your hard disks if you do. If you do a Properties on an SATA disk from within Device Manager, this option will be available on one of the tabs.
"Safely Remove Hardware" appears because the SATA standard is meant to allow hot-pluggable drives. If you have your SATA drives running in Performance mode, this is added to ensure that the system can finish writing to the drives before you remove them. If you run them the other way (I forget what it is called, not near my SATA system), it assumes you may undock your drives at any time, and disables write caching altogether, and also removes the "Safely Remove Hardware" icon from the tray, as it is no longer needed.
I've left the icon in my System tray. I'm the only one that touches my system, and it's not like it's a massive resource hog. Plus, I want write-caching enabled.
