Minimum voltage on Venice is 1.1v?
spotpuff
I am trying to undervolt my Venice 3000+ so when it runs at way under stock (1ghz or so) it can run at a low voltage. However setting any voltage below 1.1v results in the CPU defaulting to 1.1v. Any idea what's going on?
This is through windows using CrystalCPUID and checking with CPU-Z. Increasing voltage works, but there seems to be a floor at 1.1v.
This chip can do stock speeds (1.8GHz) @ 1.1v, which is incredible.
*edit* forgot to post some relevant specs.
Venice 3000+ (not sure of stepping etc.)
DFI Lanparty UT NF4 Ultra-D
Thermalright XP-120 (doesn't even get hot :confused:)
2x512MB OCZ Premier
In terms of the voltage options in the motherboard, they're from like 0.8 to 1.8 or so I think. Adjusting voltages in windows using CCPUID works from 1.1v -> 1.5v, but like I said it won't go below 1.1v for some reason.
Yes, voltage options are limited by the motherboard, but you are able to set them all in windows, and like I said, anything < 1.1v the CPU decides to run at 1.1v anyways (doesn't change in CPU-Z).
I thought voltage limits were motherboard related? I'm sure some motherboards can start from 0.8V
yeah I think the max and min voltage is set by the motherboard. and considering the DFI is centered more around upping the voltage for overclocking 1.1 is probably as high as you'll get.
on a side note: hot damn I hope my Venice can clock like that when it arrives
You mean as low as it gets? (the 1.1vcore)
I have a feeling it might be a minimum voltage instituted by AMD to ensure stability when CNQ kicks in and underclocks it.
All I have is CNQ enabled in the BIOS but I'm not using the CNQ software, I'm using CCPUID... I might try disabling CNQ and adjusting multipliers on the fly in windows; I don't see why this wouldn't work.
One note: voltage has to be set to auto for you to adjust voltage on the fly with CCPUID.
I haven't been able to oc the board past 285 and the CPU past 270 with this :T I did try upping VCore (1.5v) and chipset voltage (+0.1 and +0.2v) but neither worked; I will try some more though as the chip may be "burned in" a bit.
My Venice 3500+ will also only go as low as 1.1V on an Asus A8V-E Deluxe mobo. I'm using RMClock for CnQ stuff.
I(illa Bee said:
might I ask why you want to run 1Ghz???
CCPUID allows for dynamic multiplier adjustment based on CPU load. So when the CPU is idle I can run it at 4x267 and it will be much cooler. I'd like to drop the voltage below 1.1v as well, but so far no go, which is why I'm wondering if that's some sort of hardware limit AMD set.
