***UPDATE - the following applies for the 260 GTX:
Minimum System Requirements
Intel® or AMD® compatible motherboard
At least 512MB system RAM
50MB of available hard disk space
PCI Express® or PCI Express 2.0-compliant motherboard with one dual-width x16 graphics slot
Two 6-pin PCI Express supplementary power connector
A minimum 500W or greater system power supply (with a minimum 12V current rating of 36A)
CD-ROM or DVD-ROM drive
Microsoft® Windows® 2000, XP
VGA or DVI-I compatible monitor
Hi, Im ordering a 260 GTX today and im wondering whether my pc will be able to take the card.
My PC is a AMD64 3200+ CPU and just 1 gb of RAM i think. Im buying a new pc soon - but need to buy this gfx in a hurry - cause I need to test a HDTV i just bought - my current gfx card is having trouble displaying 1080p signals on the TV.
I read here: http://www.gainward.de/media/files/Specifications/9368_GTX260_PCX_DD_896MB_datasheet.pdf , that system requirements to the gtx 260 is 2gb of ram and a duo core cpu
My question - will it run with just a 3200+ and 1 gb of RAM?
