Minimum reqs
TheCommander
I was wondering what are the minimum hardware requirements for a PC to get into the BIOS. If I had a defective processor, would the mobo work at all and would I be able to see it on my monitor?
If you had a defective CPU the motherboard would start beeping. To get into the BIOS everything has to work. If something is broken you will get some sort of beep error code from the motherboard. I'm not sure about monitor output, I think usually no output if there is an error (or it might display the error on the monitor...but I don't think so...can't remember.).
Technically all base components have to pass through a basic post function, this does not mean those components might now have a fault or some type of issue. The best way to attempting to post a system and enter the bios if it is NOT entering in the bios is to break the system down. Use the components needed to post ( cpu , memory , video , motherboard , powersupply ) additionally if you have multiple sticks of memory try one at a time. Additionally ensure to clear your cmos first before proceeding. Be aware you will need to reset you bios values if you can enter the bios.
