Minimal PHP-based BT tracker?
RyanVM
I'm trying to setup a BT tracker on my site to help offload some of the traffic crunch my new releases generate, but I'm having a hard one which meets my needs. I just want a simple PHP/MySQL based tracker with no frills. I need to minimize the server load as much as humanly possible.
Does anybody have any good recommendations?
Thanks!
Check out BitGrog. I used to use it for a low-resource tracker. You used to be able to get it at RumAndWater, but the site is closed now. You can probably still find it if you Google around a bit.
