notalent420
- Aug 15, 2004
I'm in the process of building my new Core i7 build. I'm having a little trouble getting the 8-pin CPU power cable to reach the plug when going behind the motherboard tray.
I really don't want to route it right on top of the motherboard in sight. I was thinking about getting an extension cable in order to reach it but I was thinking there must be an easier way.
I currently have the HX620 with the fan facing upwards. Basically the PSU is upside down. I read somewhere that you could mount the PSU with the fan facing downwards. The only thing is, there is no vent for air to intake. The PSU is standing on the rubber feet, but I still think that there isn't enough room to take air in.
What I want to know is, would it be safe to have the fan facing downwards? This way I would get an extra few inches to reach the plug. It's literally a few inches away. I've tried to route the cable all sorts of ways behind the tray and still doesn't reach.
If this doesn't work, I guess I'll just have to order the extension cable.
