This is my mini project log, sort of a "whenever I do something" type a thing, all pictures are clickable for slightly larger versions. Any and all comments are welcomed, as long as they're constructive and/ or nice. I have no ambitions to be a professional photographer, so these pictures are not the greatest.
So this is what I started with, a bit of a rats nest if you ask me. The Ultra X-Connect PSU is horrible for wire management, so I picked up an Antec TrueBlue 480 off Anandtech and ordered some sleeving and other various nick-nacks from SVC.
This is what is getting sleeved.
My first crack at sleeving, not bad if I do say so myself. I did scorch the sleeving a bit with my heat gun, hence the bulges in the sleeve immediatly after the heat shrink.
My improvised ATX pin removal tools. When I placed my order, SVC was out of their PSU sleeving tool kit, so I just bought a male/ female pin remover, so I had to come up with something.
Pre-shrinking of the heat shrink.
Post shrinking of the heat shrink. If I were to do this over, I'd make sure all the sleeving was lined up under the heatshrink, I think it looks a little sloppy.
I ran out of blue heatshrink, so I wiped out some black that I had laying around. Didn't turn out half bad in my opinion.
The hole I cut to allow the ATX connector to pass around the back of the motherboard. I ended up running several wires through it in the end.
This spot is still a problem, I may end up using a piece of mirrored plexi to hide all the switch, LED, and front USB wires.
(Sorry, its blurry) I think this looks better then what was there before, much cleaner.
(Disregard the messy room in the first pic. My computer room has become a bit of a trash bin as of late.) Some finished shots, I had originally planned to stick some UV CCFL's and a batch of UV LED's, but the inverters for my CCFL's died and my LED's haven't gotten here yet, so instead I just shoved two white CCFL's that I had laying around. The blue paint on the drive bay covers is pretty close to a mirror, I'm just too lazy to try to capture that on camera. I've got more plans for this case, but wont start on them for a couple days, have to get some more materials together.
Future plans include flipping the hard drives around so all that wiring is hidden, a little paint, and some LED's distributed in strategically placed points. I've got some other ideas, nothing major, but I wont have plans until later tonight.
Anywho, thoughts? Comments? Questions? Answers?
E
E
