Mini-ITX power useage compared to Micro-ATX
Casca
I am looking to build 6 low wattage computers. I will most likely use either a 780G IGP board or a GF 8200/8300. An ITX formfactor would be great, but it's about 3 times the price for a 780G ITX compared to M-ATX. In either case I'd get a 45w cpu or lower and only use the IGP. If both M-ATX and M-ITX used the same cpu, IGP...pretty much everything the same except the mobo, would they both use the same wattage or will the M-ATX use more?
Also, can I use a 120w pico DC to DC power convertor PSU for the M-ATX? Would 120w even be enough for the mini-itx?
The 120W would be plenty for say an Atom or something, with a Core 2 or AMD processor, it would be pushing it. If you look at it like this you're already using 1/3 of the maximum output of the power supply on the CPU alone. Then you got the motherboard itself, hard drives, RAM, optical drives, etc.
If you're just web browsing and crap like that, a dual core Atom may be a good choice if they have them out yet.
Also the 120W power supply doesn't have the auxiliary 12V four pin lead for the processor, which the boards for LGA775 and AM2 require.
120w would be enough, but the mini-box PSUs have ridiculously high failure rates and no overvolt protection. If they rate it at 120w, it's more like 80w safely. The efficiency of the PSU is high, but the AC/DC brick takes that away. Also the brick they sell with it says "max 60w". :rolleyes:
Thanks for the replies, some very useful info. Looked closer at the pico psu's and yah, pretty expensive at over $100 for the convertor board and a power brick and efficiency is under 80%. Could just get an 80%+ certified antec 430watt for $40 or a 300watt antec for $10 and make the case a little bigger.
The Atom is tempting and indeed they do have the dual core 330's out. Not bad at $75 for the itx mobo and cpu. Just wish they weren't using the 945 chipset. If it came with the G45, I'd be all over it. Or if they had the Atom 330 just as a cpu and it fit in their G45 itx board, I'd do that. Probably happen around the same time AMD comes out with their 22w and lower cpu's. If so, I'll see how the G45 stacks up to the 780G then and decide. At the moment, I'd rather have a 780G IGP, but an intel cpu. Although intel's claim that their poor performance is just drivers has me hoping the G45 will prove much more capable then it's been shown so far. Anyway, the Atom 330 board would be powerful enough. I loaded what I need to run on the build into my U810 ultra-portable laptop and it runs ok on it. That laptop is very weak. single core Intel A110 800MHz cpu, 1gig ram max (solder on, cannot change), GMA 950 IGP and running Vista premium. Still, it was just about powerful enough, so I would assume the Atom 330 with 2gigs ram, running XP Pro should be fine. And at $75 for the mobo and cpu...tempting as hell. But a 780G, 8200 or G45 would run it so much better, although it will cost @$100 more per build and I need to build 6.
Also interested to see what comes out of the M-DTX formfactor, which is bigger then ITX, smaller then M-ATX. The two boards I have seen so far in DTX were crap. Reguardless, going on a trip in a couple days so I have about a month before this project goes beyond the planning stage. Hopefully a bunch of new ITX boards release durring that time
What do you want to do this for? If it is low wattage, the onboard video won't be so hot anyway. I guess it would make a difference decoding HD video though.
I too have been waiting for mDTX boards, but I think we're going to continue to keep waiting on those puppies.
This powersupply + DC converter seems to be a better deal than the picopsu offerings (which ship with low wattage bricks anyway). Bonus, it comes with a 12V ATX cable.
