Passive Anubis
- Feb 23, 2005
This is nothing super complex or high tech or anythig. Here is the most effective/cheap/noobish "outside of the box" cooling solution:
My room is pretty warm. So to bring down the temps, directly around my pc, i found this old mini oscilating fan. It works pretty well (when the power is all the way up). one day i was curious as to whether it would work in my comp. So i took it apart, pulled out the pin, and stuck it in my comp, it brought the temperature down about 5 degrees c. But then i decided it was screwing up my air flow, so i took it back out. Im about to put it back together, and i jsut wanted to take one last look at it, so heres the pic when it's on my window sill.
