Mini DP to DP
I have a gigabyte 6950 and i'm trying to do eyefinity with it. I bought a QVS mini dp to dp adapter at a local microcenter. I ran eyefinity on my 5870 with no problems. Using 3x dell 2408WFP monitors so no need for an active adapter for the DP. When I hook the 3rd monitor up using the miniDP adapter, it either doesn't show up or does but won't let me go over 1280x1024. if I go over (monitor does 1920x1200) I get lines on the screen and it's fuzzy/distorted. Not sure if its the miniDP to DP adapter or the card... would you guys recommend a good miniDP to DP adapter or should I try to just buy a miniDP to DP cable?
