I finally got my 3 monitors today
Dell P2210H's (link)
and I went to put them in an eyefinity configuration but something is wrong with the cable I bought.
I bought a Mini DP to DP cable from newegg (link)
Anyone else buy one of these? I connected everything and it will be fine for a minute but when I try to play a game at eyefinity resolutions CCC pops up and says my cable does not support this resolution, and to check the cable or my monitor. I tried plugging the cable into the other monitors but I get the same issue.
I figured that this MiniDP to DP would be the most elegant solution with no active adapters needed but either I got a bad cable or it doesn't work like this. Anyone ever try this eyefinity solution?
