Jun 4, 2014 #1 Q Quartz-1 Supreme [H]ardness Joined May 20, 2011 Messages 4,257 Are the mini-DP ports on AMD cards - particularly the 295X - limited to 1600p or can you drive a 4K monitor at 60 Hz off one? Last edited: Jun 4, 2014
Jun 4, 2014 #2 P Pitbull Limp Gawd Joined Aug 21, 2004 Messages 361 I believe Mini display port spec is maxed at 2560x1600 period.
Jun 4, 2014 #3 F Final8ty Gawd Joined Jun 13, 2006 Messages 1,001 mini-DP and DP have the exact same bandwidth specification, only the DP revision matters.
Jun 4, 2014 #4 V Venomous Gawd Joined Aug 14, 2006 Messages 663 295X2 does 4k with ease off each port, so don't sweat it. The new 1.3dp standards will dish out 8k and the new AMD cards should be 1.2a ready since 1.3 was just signed.
Jun 5, 2014 #5 KazeoHin [H]F Junkie 2FA Joined Sep 7, 2011 Messages 10,252 Mini Dp is identical to DP, I'm sure, so it can run 4x 1080p screens, 2x 1600p screens or a single 4k display.
Jun 5, 2014 #6 Q Quartz-1 Supreme [H]ardness Joined May 20, 2011 Messages 4,257 Excellent. Thanks all.
