I'm looking for a thin and light laptop with GTX-1060 (under 5lbs). Seems the choices are fairly limited unless you want to spend about $2000. The only two option at the $1500 range is the ASUS GL502VM and the MSI GS43VR Phantom Pro.
The only problem I see is that neither one have HDMI 2.0. which I would need if I want to connect to my 4K TV. The only option I can see is using a Active Mini DP to HDMI 2.0 adapter. Anyone have experience with those? Is there any additional lag induced by the adapter and if so, how much more?
