What the hell.
So my radeon 6950 comes with dual DVI outputs and some miniDP outputs, and I'd like to be able to use that fancy new Displayport with my NEC PA271w.
All well and good, until I try to load up any kind of 3D application. Then the screen begins to show garbage and/or drop out complete every 4-5 seconds. I went through two separate (active) miniDP-DP adaptors before giving up and going back to dual link DVI.
So what gives? Has anyone come up with the bright idea of simply making a miniDP to DP cable without having to go through adaptors that clearly don't work?
Even better, why not just put full size DP outputs on the cards?
