hmmm i like... if i didn't think the psu would be total crap, i might would consider it.... and its not like you can switch it out with a good one....
think this would be able to handle an athlon xp at low clocks, a geforce 5200 fx, a tuner card, a dvd-rw and an ide hard drive?
I have a Celery331 in the ECS Fry's mobo, + PCI WiFi & AIW9600XT in a similar InWin setup (less than 200W PSU), and it chugs along quite nicely as an HTPC. I'd put an AXP system in this no worries. Anything up an lower-end A64 would prob be fine if you weren't asking it to push a big GFX card constantly.think this would be able to handle an athlon xp at low clocks, a geforce 5200 fx, a tuner card, a dvd-rw and an ide hard drive?
I'm guessing this would work well with 1 disk, 2 ram sticks, 1 dvd-rom/slim (?) and a be-2300 or be-2350
Rob
Source please? Tempted if true...The one at SVC is pretty decent. It has an Enhance PSU and should be able to handle a decent amount of load.
I got the $20 GlobalWin cases today undamaged by regular UPS (no double boxing). Both came with the Enhance PSU shown in the madshrimps review. It's a very light case and the optical drive mounting is good. It fit a regular microATX motherboard perfectly and the stock AM2 cooler fits OK too. Hopefully this will work OK for a X2 4400+ EE system.
That I could actually consider owning.
