I was thinking of doing some mild overclocking and was hoping someone can give me some figures for the below system
MSI - K8N neo 2 platinum
AMD 64 3200 athlon (venice)
1gb Corsair value select DDR pc3200 / 400
Im not looking to be the fastest kid on the block, i would just like to get a bit more from the system without my cpu dying prematurely. I know the memory my be a sticking point so do you think aiming for upping the processor to 2.2ghz is asking to much. I have core centre installed and had a little dabble at upping the fsb. I set it to 210mhz and the system seemed ok so i upped it to 220mhz which resulted in an immediate bsod. What i also need to be careful about is the pc is a dual boot and i dont want the person using the other partition to be getting crashes. I know nothing about overclocking so if someone could give me some figures i could work to, that would be great.
