I need to setup a network with VLANs so that I can operate a guest wireless network alongside our secured wireless network. Each one will be on a separate VLAN. I'm planning on using UNIFI APs for that part.
I have been looking for a L3 switch to do the routing between VLANs:http://hardforum.com/showthread.php?t=1678294
However, now i'm thinking it would be more cost affective to just use a Mikrotik RG750GL to do the routing between the VLANs.
I have never setup a Mikrotik router before so I was wondering if there is someone out there that is good with Mikrotik that could give me the cliffnotes version of how to set this up.
