Migrating a Raid array to replacement mobo
J
jsilva
Guest
First of my Raid-0 array is fine, the issue I'm having is with my motherboard, seems its day has come to go to computer heaven. :( I DO HAVE a backup of my system partition that I made with Acronis, but before I go that route I would like some help with these 2 scenarios please...
First scenario: If I clear the cmos and/or reflash my current board and let's say that fixes the problem and it works, can I just plug everything back the exact same way it was before and just change the bios settings and boot?
Second scenario: If I get an exact replacement of my motherboard, can I just plug everything back the exact same way it was before and just change the bios settings and boot?
Any specific steps I should follow on each? Thanks in advance for your help!
You should be fine with either option. I upgraded an old board years ago with the same onboard (or one version newer) and it was just a drop in. No rebuilding (not that you can do it on a raid 0) or no further setup.
YMMV
So in both cases I just mimic my old bios settings, eh?....I tought I needed to go back to the actual Raid Configuration Utitlity (not the bios) and "reset/recreate" or something...(without erasing the disks of course)
Well, your answer makes me feel a little better although I know that with computers there's always surprises...going to try the clear/reflash bios tonight. If not i'll get a board replacement which i already found for $50 so its not that bad. Thanks!
Well, scenario 1 is out the window...now my system won't do a complete boot at all. A few times it passed the "starting windows" and almost got to the password prompt, but then it restarted itself over and over. :(
Cyant, I already checked the ram in another pc and it works...I'm almost 100% sure it has to be the mobo because it all started with the usb ports dying one by one and then having video problems at boot (but then it will work for a while) and finally started having other weird boot related stuff. Plus it's 3.5 years old...so I can't complain that much. I already bought the replacement and is on the way so lets see what happens. I will post an update after I install the other one in case anyone is interested. Thanks to all for taking the time to help out.
UPDATE.....
Just to let you guys know that the motherboard replacement was a total success!!! The new board booted up my Raid-0 with no problems and all drivers and devices are fine. Thanks to everybody for taking the time to help.
