migrate of system (Possible?)
stevyd10
Hi,
I was wondering if it was possible to put an xp install onto another motherboard?
Basically i am upgrading motherboard and graphics card to an xfx 780i and 9800gx2 from an asrock mobo and x1950pro.
I have software that will allow me to create an image of the entire drive. I need to do this as i have a raid and will need to re-do the raid on the new mobo. Is is then possible to simply put the image back onto the hdds and boot up and everything will be back as it were in the old system? of course i will need to install the new drivers for the chipset and graphics cards.
Has anyone had experiance with doing this and was it successful?
Should i remove the old graphics and chipset drive before making the image?
Is there anything else i need to prepare before i do the image and anything i have to do after installing the new components?
Thanks for any help on the issue!
I've never had any luck with transferring an image from one set up to another. I'd just give it a shot but be prepared to do a clean install if it doesnt work (back up all your important data first in other words)
Def remove all of the drivers for hardware that wont be present in the new set up before making the image, if it does work windows will detect the new hardware and prompt for drivers
thanks for the quick reply.
In making the image i will have a backup anyway but i will make sure all drivers are removed. Please could someone advise me on an easy way to do this and exactly what i need to remove.
thanks
