Benzino
- Mar 3, 2005
I have a Giga-Byte 8IPE1000 Pro Rev 2 with a Pentium 4 2.8 gig processor (800mhz fsb). Last week, I decided to go into the BIOS and increase the multiplier. If I had bothered to research it, I wouldn't have done that, but I did. My computer shut down, and has yet to start. I conversed with some people at Gen[M]ay forums, and they recommended to reset the CMOS. I spent all week pulling out the battery, puting it back in, and other methods to reset the CMOS, and none have worked. I even contacted Giga-bytes support line, and they recommended the same. I have concluded that the CMOS is not the problem. This leaves me with a dilemma between two choices.
1)Continue to research the problem and a solution in hope to fix it without spending any money.
2)Assume my current mb is trashed, crack it over my knee (ouch) and buy this one at Newegg.
I'd prefer #1 if I can find a solution here, but if all else fails, I will reluctantly go with #2. I didn't find much help at Gen[M]ay forums, so I figured I would have a try here.
Suggestions? Comments? Help?
