Mid Tower for Watercooling?
Atara
I recently bought a corsair 800d for my new build but it's just too big! I really like the case but it's just too much for what I've got in it. I'm looking for a case that will fit a 2x120 radiator (some modification is alright with me) along with my hardware in sig. A black interior would be awesome, I'm also a big fan of the black interior (I've got my side panel off most of the time). The Corsair 600T caught my eye and has pretty much everything I'm looking for but I haven't been able to find out when that case is going to be available.
coolermaster cm690 ii is the best water cooling ready case for under $80 with dual 2x120mm ready out of the box.
Thanks! That does look like a good option. I like that it has holes for routing cables as well as mostly everything else. I think I may pick that one up to hold me over for the 600t.
A little modification you say?
I'm always glad to post my Antec 902 modded for 2 triple radiators,
Inside: pump is on the bottom. inside the moveable hard drive cage. I also tore off the side plastic piece with the fan on the side panel. It just took up too much space.
One just for fun,
It's a little cramped in there. I have another video card and hard drive coming too. Have to dig up some room.
And yes the cable management is lacking. Corsair PSU's are good, but damn are those cables long. :eek:
Just all depends on how much you want to mod or none at all?
I have a CM590 with a i7-965 and GTX280 on a BIX240 and it works great, and still got a Bluray and 1TB HDD in the machine. Just need these from lian-li. Only thing I had to do was bend the drive support tabs in the 5.25in bays.
