Mid tower case with PSU on the bottom...?
indokyne
could you guys help me list out some midtower cases that have the PSU's located on the bottom? I know the Lian-li's are would be a popular pick... any others?
and I'm not looking for full tower cases...
thanks in advance.
Lian Li or antec P180, that's about it, someone correct me if i'm wrong...:p
The most recent iCutes have their PSUs on the bottom... at the front... through a passthrough from the back panel for your IEC cord. They also have a 220mm fan on the side as well, and don't look too bad for the money.
pretty much unless your want a heavy mod you are stuck with the PSU on top in mid towers unless you want a lan li or p180. Why do you care if the PSU is on bottom in the first place. In most cases it makes things more difficult for wiring. You need extra long cables on the PSU to hide them when its on bottom.
actually - with the psu on the front bottom, the wires don't have to reach that far for things like IDE drives...
the only thing in the upper rear part of the case is maybe the exhaust fan and maybe a motherboard 4 pin connector...
P180 -
SilverStone TJ09..I want it in blaack ...WOOT :D :D
And of cousre some of the Lian li box's in the 1100,1200,2000 series
ThirtySixBelow said:
I really want that case. Hopefully it comes out soon.
Well I called SunDialmicro and was told the end of sept..or first week of Oct..so not to long..I want a black one 4 Sure :D :eek:
in case anyone was wondering - the reason I was looking for a case with the PSU on the bottom was so that I could potentially get a 120.2 or 120.3 rad mounted on the top without losing any of my 5.25 bays
Sounds like a plan..let us see it when your done..So you like the case I posted??
