Mid tower ATX case upgrade
aradeath
decided to paint the inside of my case before i added a larger radiator to it..
this will be the only post, except to answer any questions.. thanks
Nice work, really added character too the case. Also makes your components stand out. Wish I had to guts to paint the inside of my case. Nice job.
haha, thanks.. its not hard.. just requires about an entire weekend's worth of time :rolleyes: .. and a little prep with a little masking tape :p
Nice paint job.
I've got that 2fresh rad too. You'll get much better airflow and less noise if you shroud the fans.
High resistance cpu water blocks like yours enjoy being 1st in line after the pump. You may get better temps that way. Try pump...cpu...gpu...NB....rad....res...pump
Try to ditch the 90 degree elbows too...they're also flow killers. You'll need all the water flow you can get with 3 blocks and that relatively low pressure pump.
Ruiner said:
Nice paint job.
well thanks for the input, but i have had no problems with flow in this system... and i really shuld shroud the fans but for now its good..
and when i say thers no probs with the flow, i can see a strong current in the res while its on.. and the cpu is oced to 3.0ghz from 2.4 @ 250 fsb 1:1, and the vid card can run at 450/370 even in the summer heat :p..
all in all its a great rad, and thanks for the input :D
