Microsoft's Patch Tuesday Features IE8 Zero-Day Fix
CommanderFrank
Cat Can't Scratch It
It’s Patch Tuesday time again with Microsoft offering a total of 10 security updates addressing 34 vulnerabilities including a critical patch for the IE8 zero-day flaw.
The remaining eight updates, called "bulletins" by Microsoft, were pegged as "important" on the firm's threat scale, and will provide patches for Windows, several applications in the Office family and for multiple communications products, including Lync, Microsoft's enterprise-grade instant messaging platform.
do people really get annoyed by a reboot?...even if your system takes 5 minutes to reboot just go use the bathroom, eat some cake, take out the trash etc...a reboot is not a big deal...I even shut my system down quite often :eek:
Mine takes about 30-35 seconds from desktop-to-desktop. If people are annoyed at that then they are quite petty individuals.
I don't think most anyone cares about a reboot, but Linux users need a way to stay relevant, and acting dramatic over a reboot is what they're reduced to these days. Needless to say, last time I messed with Ubuntu, it required a ton of updates, and several reboots after first install.
Yes. Reboots become far more annoying when you get used to not having to do it. In addition to booting the operating system, I still have to reopen all of my programs as well.
It shouldn't require multiple reboots. If it does, they are incompetent. Ubuntu is a bad representation of GNU/Linux because it is mostly staffed by a bunch of Microsoft wannabes who want to emulate Microsoft and their style of programming.
I can tell you that I never have to reboot for software updates on Arch. The only thing that requires reboots is kernel updates and even then, it is possible to update the kernel without rebooting with things like KSplice (and kernel updates aren't as critical as in Windows because in GNU/Linux, we don't put everything into kernel mode where it is a security risk).
With Windows, on the other hand, even something as simple as updating Adobe Reader or Internet Explorer often requires a reboot. If an application on GNU/Linux required a reboot, the programmers of said application would be tarred and feathered for their incompetence.
In addition, not everyone has a fast computer. I've seen plenty of regular users who put off Windows Updates because it is inconvenient for them to have to reboot and they don't want to leave their computers on when they aren't using them (which wastes power).
Then why not switch it off? That scenario makes no sense, and you are stretching for things to whine about. Or you have zero clue what you are talking about (most likely).
While KSplice sounds nice in theory, I believe the argument put forward by MS was that such update mechanisms have a small but non-zero possibility of leaving the system in an inconsistent state, so they forego implementing such a thing. And apps like adobe reader requiring a reboot are due to adobe reader programmers, there no reason it should require one to display documents on Windows, and there are tons of documents displayers on windows that don't require reboots to update. IE is a special case, it's rendering code is used throughout the system and in user programs, etc. To apply a security fix such that all of them start using the new update, pretty much requires a reboot, afaict.
